Hello developers,
I was just wondering how useful some kind of plugin system would be? For example an extended FFGL API, or something like that? Or is OSC the future (and enough to interact with Resolume)? What do you think?
for example thinking of: BPM clock, MIDI/DMX, playback speed, direction...
Resolume PlugIn System
Re: Resolume PlugIn System
I think I know what you're getting at, but would you care to elaborate a bit?
Hi Joris,
Well, I'm not quite sure if a "plugin system" is the correct term, so I hoped we could elaborate together
Basically I'd like to be able to READ a few values out of Resolume to be used within FFGL plugins.
Examples: BPM - a way to get the current (sub)beat
FFT - get the audio FFT analysis of composition (and maybe clip)
Besides that, it would be nice to be able to change some basic controls from within a plugin: playback direction and speed. Get access to the clip's timeline would be awesome! (that way a plugin would be able to set the start point of (within) a loop, without cropping it. e.g. if you know the total number of frames of a clip, the plugin could tell the host which frame should be next).
I could go on, but would like to hear your opinion first
And no, I don't think we need another Modul8
But maybe FFGL2.0 ?
IROSCRene wrote: Get access to the clip's timeline would be awesome!
yepp, OSC is one solution, but going the IP path is not always best (and fastest).VJair wrote:IROSC
