video cards with four outputs
levon_
Post by levon_ »
i was just wondering what video cards that have 4 outputs have been tested with resolume.
thankyou for all the great additions to resolume, after i buy a new computer resolume 2.0 is next on the list
timEther_
Post by timEther_ »
we have developed the multi screen feature on a system with an ati 9600 AGP and an ati 9200 PCI videocard. Both with two outputs
grom_
Post by grom_ »
pci performances are ok with resolume 2 ?
SuperficiaL_
Post by SuperficiaL_ »
hi,
if pci isnt fast enough maybe you should wait for the new pci extreme.
new pci standard that will be on the newer motherboards...
my gues is there will become more and more extreme pci graphic cards available over the next year or so.
Greetz,
SuperficiaL
levon_
Post by levon_ »
ok one more question, i have a Geforce 4 ti 4200, would a ati PCI card work, or do i have to use a Geforce PCI card? afaik the geforce 2's were the last nvidia cards that were made with PCI.
anyone know about this? thanks
SuperficiaL_
Hi Levon,
i dont think that will be a problem...
i used an Invidia graphics card and the cheapest 8 mb (pci) videocard together. was under windows 98 so im not sure, but i would be heavilly suprised if it wouldnt work...
good luck,
SuperficiaL
levon_
Post by levon_ »
thanks for the help, at first i though i would have to go buy some sort of videocard with 4 outputs, but its nice to know that it might work with my current system. thanks
