Hey Guys,
Im producing a lot of content at the moment and ive been producing it in white. Ive been working in After effects and its mainly white vector.
I like to work with a wide colour palette but dont want to make the clip in all the different hues (ideally)
I've been looking at colour effects and the only ones i can see to find are the colorize and also add subtract and invert RGB.
Is there a simple RGB that just can be used to make custom colours or are these plugins the only option?
With the colorize plugin you can change the hue which is great but i dont feel like it has the control that an 3 separate sliders would have. R,G, B.
Hope this has made sense and if someone has come across something similar it would nice to know.
Basic
Quick way to colour in AVE
Re: Quick way to colour in AVE
Yes...there is something u can use.. it called "ADD SUBTRACT"
If u want to get yellow for example u have to subtract the colour Blue with den RGB Faders of the VFX..
Greets
Greets
Do you like outlines? Easy Outliner on Juicebar Re: Quick way to colour in AVE
Thanks Cosmowe i need to have more of a play around with it! Thanks
yeah i also requested a colour spectrum which i think would be great but i dont think it will be implemented. res 4 will be out hopefully next month so we shall wait and see.
