How many video cards/instances of resolume can I run on one pc?
We wanna use this coolest of software to drive 10 monitors. Does anyone have experience running more than one instance of resolume on the same pc simultaneously? I don't need to run video so much as a series of stills keyed off different midi channels. I'd like to run 3 or 4 instances off a pc because I only have three pc's available for the gig. I'm figuring on getting a few more pci cards and going from there. TIA,Kevin
Well I installed resolume in three different directories and tried to run one instance of each. It worked ok with two, but when it got to the third, I got--"Exception Ewin32 error in module Resolume.exe at 0000d68c win 32 Error code 87 The parameter is incorrect." We are running win98 se. If there is any way for you to make it possible to run three or more copies off one box, well life would be a dream! Please advise. Many Thanks, Kevin
it is possible to run two instances of Resolume in win 98. But when you start the third the system runs out of system and GDI resources. In win2k or winxp you won't have that problem because the resource management is different from '98. Anyway i succeeded in running 7 instances of resolume under win2k and i havent' even tried to start more.
have a look a this screenshot so you know i am not kiddin.
screenshot
So your dream will not come true unless you start using win2k or xp..
cheers
screenshot
cheers
