2 sessions of Resolume on the same PC, possible ?
GuruMeditation
Post by GuruMeditation »
Hello !
I am working on a projection mapping with 4 FullHD projectors.
I would like to use Resolume with IRmapio for this project.
I know that Resolume only allow 4000 pix size resolutions, if I have 4 FullHD stream, it is not possible.
So my question is : can I run 2 sessions of Resolume on the same machine ?
resolume 1 will run the 2 first part of the screen
resolume 2 will run the 2 second parts of the screen.
I think I can configure position of each video with the advanced screen setup.
The hardware will be :
Dell precision R5400 worksation
2 Xeon processor
32 Gb of RAM
1 Velociraptor for the system
2 SSD for the medias
1 Geforce quadroFX for the interface screen
1 Matrox Matrox M9140 for the 4 outputs to the projectors.
Thanx for your help !
HerrNieDa
Re: 2 sessions of Resolume on the same PC, possible ?
Post by HerrNieDa »
you can arrange the outputs in 2 rows in one resolume... only the effects won't work like the way with 2 resolumes.
don't know if 2 instances run and also give outputs...
i think 2 machines would be the best solution anyways ;) (and you can sync them with midi or osc patch)
