Hey,
since a couple of friends play in a band they wanted that i accompany them with some visuals..
But working now with Avenue and lucky me has an APC 40 i have a bit of a Problem adressing the Clips in the 2nd and 3rd Layer..
When im trying to Edit Application Midi Map i'm only able to map buttons from the APC on Layer 1
I can imagine this problem occured already to different persons, though i couldn't find anything using the search function.
Not able to map Layer 2 & 3
- Attachments
- reso_midi.tiff (166.82 KiB) Viewed 4017 times
Re: Not able to map Layer 2 & 3
Hi peda,
in the lower right corner enable "Focus: Deck" - And yes, you should RTFM
And also upgrade to the latest version!
Oh..i'll be in the books from now on..
Thanks very much - what an relief
