Insert X count of layers & rows
Hey Resolumes,
it would be great to have a function wich let me insert a specific count of layers and/or rows in my composition.
Often I want to add 20 and more clips in a layer between two clips...
...at the moment I have to rightclick a row and "insert row, insert row,insert row,insert row,insert row,...." manual...
Would be nice if I could say "Insert 20 rows" >> APPLY!!! ;)
Greets
Basic
Re: Insert X count of layers & rows
Post by Basic »
good idea! is there a keyboard shortcut you can use or is it just all right click>insert?
;) Whatever.....
Hey Cosmowe
In R4 you'll be able to move blocks of clips around, so you can move clips out of the way, and then just drop your 20 new clips.
Sounds good....thx
