Video Capture Pin Settings within Resolume 3
offthesky
Post by offthesky »
for some reason resolume 3 PC is loading my usb camera in at the default low frame rate. with other programs (such as captureflux) - i can up the frame rate of the camera with the 'capture pin' settings control panel... in resolume 3 i can only access the cameras filter settings (brightness, contrast, etc). anybody know if you can access a USB camera's capture pin settings panel within resolume 3?
attached is a pic of the pin settings panel as seen using captureflux...
17" macbook pro | i7 2.3ghz Quad | 8g 1333MHz DDR3 | 512 SSD | OSX 10.6.8
