how to get a direct cut from one clip to another
Media Selectah
Post by Media Selectah »
Hello,
I need to know how can you do direct cuts with Resolume?
1. From one layer to another,
lets say layer 3 to layer 2 without any trasparent parts, and without having a fade in.
2. From A to B
without the slide having this crossfading time?
Like a direct cut or direct take, they use to call it in the old mixers...
Hope you can help me,
thank you
Re: how to get a direct cut from one clip to another
Hi Media Selectah....
there a some ways to get a direct take....from one to another layer
1. Use the Bypass button or the solobutton
2. Use a external controller to send a opacityvalue 0% or 100% for the upper layer
3. Click inside an empty clipfield in the upper layer so that the lower layer gets visible
4. Use your mouse :) very very fast!
Greets
Tschoepler
Post by Tschoepler »
Using MIDI or OSC to set the crossfader to A or B immediately.
