Mixing modes
VisualsOnSound
Mixing modes
Post by VisualsOnSound »
All my layer mixing modes are set to Alpha. When trying to select a different one, I get:
"no choices"
Re: Mixing modes
Double check if the path to the plugins is correct on the Video tab of the Preferences.
gradek
Re: Mixing modes
Post by gradek »
I also had this problem with the install of the Avenue 4 BETA. changing the plugin directory did fix the issue. Not sure why the default install was set incorrectly. Perhaps it was looking at the old Resolume 4 Alpha folder. Arena did not have the same problem and installed fine.
