When having a footage from deck whatever inside whichever layer, I’m switching decks for other images and then i want to add an effect to that currently playing footage from the earlier deck. So i select that layer and the clip properties jumps into the properties pane as it should (and thank you for fixing that from RES3) although i am on a different deck then the one the playing clip belongs to. Now, when i try to add an effect to that clip by dragging it from the effect pane to the properties pane, the effect is being added to the clip that has the same position in the grid as the currently playing clip in the currently watched deck.
Yes, complicated description but i hope you understand....
Effect insert glitch
Re: Effect insert glitch
Yup, we're aware of this one. Confused the heck out of me the first few times I came across it. Thanks for the report!
Haaa you are a slow one...
took me 25 secs and another 15 to confirm
