Resolume 4 Beta 2 Now Available
Thanks to the feedback from so many of you we have been able to make many improvements and bug fixes in Resolume 4 Avenue and Arena! We're not quite done yet but here is a second beta release so you can enjoy the bug fixes and improvements we have made so far.
Login to your account to download Resolume 4 Avenue and Arena Beta 2.
http://www.resolume.com/shop/account.php
Advanced Screen Setup
The advanced screen setup window now includes a new perspective corrected transform on the slices. With this new transform it's easier to map tiles on a building and the tiles in the video will more easily line up with excising tiles on the wall. The memory usage of the slices is dramatically reduced so you can create a LOT more slices without any problems. Also many small bugs and improvements have been made to the advanced output window.
Drag Clip to Layer
You can now drag a clip to a layer so it's super easy to quickly play a clip from layer 1 in layer 3 for instance. Just pick it up and drop it on any layer to trigger the clip. We love small ergonomic improvements like this!
QuickTime & DXV on Windows
On Windows we're now using FFMPEG to open QuickTime files encoded with our DXV codec. This way QuickTime does not have to be installed but Resolume can still play .mov files encoded with DXV. All the example footage in the installer is now DXV.
Other fixes and improvements
[FIXED] Movie files are not shown in clip reconnect dialog
[FIXED] Big Memory Leak! (OSX)
[FIXED] Composition settings window resolution dropdown does not get dismissed when window is closed
[FIXED] Warning: You have entered a serial for Avenue but this is Arena
[FIXED] Column application menu is not updated after clicking a column
[FIXED] Parameter animations speed changes when importing version 3 composition
[FIXED] Parameter FFT settings from old composition no worky
[FIXED] 4th mode to scale to composition
[FIXED] MIDI CC OUT issues
[FIXED] AutoPilot not working when change the startpoint of a clip
[FIXED] Scaling Quality 'Nearest Neighbor' doesn't seem to work anymore
[FIXED] If you assign a midi control to the Clear Layer button in any layer, you can only push that button ONCE for the entire duration of any session of running Avenue
[FIXED] Crash while adjusting the in-out points
[FIXED] Screen that is not connected anymore is 0x0 in size
[FIXED] Crashes on shutdown
[FIXED] Crash when dragging audio clip from one row to another
[FIXED] Flash text input field needs black (dark) background
[FIXED] CommonDataPath: C:\ProgramData\Resolume Arena 4 logged too often
[FIXED] Clip parameter 'paused' in timeline mode jumps back to the beginning when clip is triggered
[FIXED] Move points of slices in bigger steps when you hold down the 'shift' key
[FIXED] Crash: Open advanced screen setup when it's minimized
[FIXED] Add slice name field to transformation tab
[FIXED] 8000px by 8000px PNG crashes Avenue
[FIXED] BPM only supports whole numbers
[FIXED] Crash when moving layer effects
[FIXED] Sending BPM via OSC is not normalized
[FIXED] midi limit is not remembered
[FIXED] Values higher than 10 beats for the BPM synced parameters...
[FIXED] Clip panel confusing when movie file contains both video and audio
[FIXED] FileList with a lot of files is very slow on Windows (maybe also on OSX)
[FIXED] Limit memory usage of slices
[FIXED] Clip target not saving
[FIXED] Crash when you choose 'reset to default' in presets box
[FIXED] Deadlock when triggering a bpm synked audio clip, after relocation
[FIXED] If I push the left and right loop markers completely together I can't pull them apart again
Basic
Re: Resolume 4 Beta 2 Now Available
Post by Basic »
Wow, great work. Will need to give this one a whirl!
Tryll
Post by Tryll »
Excellent! By now, Beta 1 was a dead horse. I'm looking forward to beating on this one and generating some new reports. :twisted:
Seriously though... you guys just made my weekend. Great "FIXED" list!
Dickvj
Post by Dickvj »
Beautiful, the long-awaited.
