Future?! Resolume 1.1 feature
Roeligan_
Post by Roeligan_ »
I don't kwow if you already planned this feature in your next update but it would be kewl/wicked/vet! (you name it) to include something like a beat-dection. (like in VLIGHT-MXR for example)
Can you tell me wenn you are planning the next 1.1 version? Winthin few weeks as is said in the "Next Version Update" topic should be...late April now?
greetings
zeist_
Post by zeist_ »
also usefull if you could drag applications into the source box. like an animation programme for instance...
Ok here is a list of new features that will definitely make it into the 1.1 update for which we wil be releasing the beta version ASAP.
- Transitions
Use the default transitions or make your own.
- DVDMax support for Matrox videocards
Super easy dual monitor setup. Just startup resolume and you have fullscreen image to your second monitor and the interface including video preview on the first monitor.
- Dynamic flash text
Dynamic text in flash movies. Create your own flash movie with a text field and then enter the text that it should display in Resolume. This way you can use your own style animations but also be very flexible. Every time you do a show you can use the flash movie but make it display different text in Resolume.
- Improved midi features
Control a lot more parameters with midi.
- Improved speed with dual monitor setup.
The output window can now takeover the second monitor for fullscreen output, improving the playbackspeed. This should fix all the dualmonitor speed problems with Geforce dualhead videocards.
- Layer masking
Use any grayscale image to create a mask on a layer.
- Some xtra effects
- Improved live input
- General performance improvements.
- Shorter trial period (15 days)
- Some last minute surprises.
Just to be xtra safe we will first release a beta version of this update to make sure we release a rock solid final 1.1 ...
