Ive had a weird problem with Resolume 2 beta, where I cant load files properly. I can browse around the C:Program FilesResolume-2-0-beta folder and succesfully load any file in there, but cannot load any file (except bitmaps (???)) outside that folder. Resolume 1.5 still works fine though. Any ideas ?? Very weird.
Ive reinstalled a couple of times to try n help it, no joy. It worked fine when i first started using the ap also.
Another weird thing was Resolume asking for a disc in my cd/dvd drive on start up ?? This stopped after the last reinstall.
Ive also found a bug where resolume 2 can get stuck when u try browsing the root of a computer, when you have more than one hard disc.
Anyway, apart from these issues I LOVE RESOLUME !! Thanks so much for the great new features, all your hard work is well appreciated.
Anyway - any ideas on my problem ?
James
Files not loading
