Question: Is my computer the reason for slow framerate in Resolume Arena?
Specs:
CPU: Intel 2nd genreation i7
Ram: 8 gig
OS : Win7 64bit
GPU: Intel integrated / ATI (1Gig RAM) Dedicated switchable
When playing 1080 HD captured source in Media Express (Black-Magic Design App) the video is smooth and perform typically .
But when rendered via Resolume Arena, the video capture is very choppy and latency is high.
Resolume is running okay with example footages and multi-layer, but not with Intensity Shuttle source.
Hope the developement team can support this.
Intensity Shuttle low framerate
Re: Intensity Shuttle low framerate
Hi, I am having the same problem. have you found an answer to your problem???
Gygabite GA-P67A-UD7-B3 MotherBoard / Gygabite HD 6990 Video Card/ Aja Kona 3 Card/ i7 2600 Processor
fruitygreen
Not yet.
Wonder if its got something to do with OpenGL.
Sorry, but I may not get enough support.
Hmmmm.edwin wrote:Make sure that the card the UI is running on is the best card you have in your system. The UI contains the main OpenGL context which everything is rendered in, so choosing a lesser card is actually the worst thing you could do.
fruitygreen
4.1 update was the solution.
Intensity Shuttle via Laptop USB3 now works properly with low latency. Just upgraded to 4.1 and tested my laptop.
Although this lappy is for other setup , it is nice to know I can HD capture with it . My Matrox latency is a little too high compared to Intensity Shuttle.
Thanks Resolume Team.
