Can anyone give advice as to what kind of VGA extender that is good for extending to Matrox 3plhead2go.
Something that can atleast do 3840 x 720.
Thanks in advance.
VGA extenders
Re: VGA extenders
...extending to Matrox 3plhead2go
hmmm...did't get it! Do you mean a distance extension for VGA?
Do you like outlines? Easy Outliner on Juicebar Re: VGA extenders
Hi,fruitygreen wrote:Can anyone give advice as to what kind of VGA extender that is good for extending to Matrox 3plhead2go.
Thanks in advance.
I have done this once, using a dual head to go after the extender but I would have thought that normally you would need to extend each of the TH2G outputs using the VGA extenders that I was using, especially at high resolution.
When I did this using a DH2G I powered it using a USB hub. It worked fairly well but the screens seemed to loose signal sometimes when I went to black. That may have been a setting on the LCD screens rather than a problem with the DH2G running at a distance.
Tim
Re: VGA extenders
yeah id probably put the extenders after the thtg -3840 x 720 is going to be above the resolution of most vga extenders.
we use the Kramer units - not the cheapest, but never had a problem with them.
fruitygreen
Re: VGA extenders
Yes, I have extenders from the 3H2GO. 3, 1 for each output projector.VJair wrote:yeah id probably put the extenders after the thtg -3840 x 720 is going to be above the resolution of most vga extenders.
Let me ask this another way.
Is there a VGA extender that can output 3840 x 720?
So I can extend from my computer to a cluster of projectors in near proximity. Using just 1 cable as opposed to 3 .
Thanks again
Re: VGA extenders
hi, i think that does't work cause the TH2GO has to comunicate with the grafic card in the computer. tihs is not possible if the signal is changed.fruitygreen wrote: Is there a VGA extender that can output 3840 x 720?
i tried something on a event:
i put a kramer vga spliter between th TH and the projector... works not (no signal).
with the kramer vp- 4x4 (VGA matrix) between the pc an the TH the signal was here but the quality was reduced.
so the solution was to take a 25m vga cable fron the pc to the TH and 3 x 35m cable from the TH to the projectors... this works fine.
hope this helps
