Cue Points
VJVertex
Cue Points
Post by VJVertex »
i don´t know it´s new in 4.0.0, if i push any cue button (Q,W, aso.) it jumps to the next.
if i push "Q", Q-Cue starts, if i push "Q" a second time the "W-Cue" starts...
with beta 2 and previous buttons i had never problems with the cue buttons (i used via midi)
i first tried with midi and thought my midi controller has crashed, but i deleted every midi mapping and had this effect and than i noticed it´s the same while using just the normal keyboard keys
what can i do?
any ideas?
thx!
| EVGA SR-2 | 2 x Intel Core i7 X5650 | 48 GB Corsiar DDR3 PC12800 | 2 x HD5870 Eyefinity 6 | 1 x GTX580 | 256GB Samsung 840 PRO | 160GB Intel Postville | Win 7 X64 | Resolume Arena 4 |
Re: Cue Points
Yeah this is a bug, it's on our todo list. Sorry we do not have a workaround for now ;-(
Tschoepler
Re: Cue Points
Post by Tschoepler »
Workaround: Use OSC messages, they still work.
VJVertex
Re: Cue Points
Post by VJVertex »
hmm i´ll try it...
@ bart, how long do do think it´ll take to solve the bug? :)
Re: Cue Points
This has been fixed and will be released in the 4.0.1 update, slated for Feb 1st.
samwab
Re: Cue Points
Post by samwab »
Tschoepler wrote:Workaround: Use OSC messages, they still work.
How did you implement your workaround? What software did you use? I note that the on-screen buttons still work. What is the most suitable software to translate from keystrokes and/or MIDI to OSC messages? I had a crack at a Processing script but I couldn't get it right. In any case it would only work while the processing application was selected. Can anyone help me? I'm planning on using 4.0 for a gig next week but I depend on the cue points feature for my set.
Code: Select all
A half finished attempt to convert QWERTY presses to appropriate OSC messages.
// start OSC config
import oscP5.*;
import netP5.*;
/*portToListenTo, port we are listening on, this should be the same as
 the outgoing port of TouchOsc on your iphone
int portToListenTo = 8000;
/*portToSendTo, port we are sending to, this should be the same as
 the incomning port of Resolume 3, default it is set to 7000, so you wouldn't need to change it.
int portToSendTo = 7000;
/*ipAddressToSendTo, ip address of the computer we are sending messages to (where Resolume 3 runs)
String ipAddressToSendTo = "localhost";
OscP5 oscP5;
NetAddress myRemoteLocation;
OscBundle myBundle;
OscMessage myMessage;
//end OSC config
boolean newMessages = false;
void setup() {
  size(10, 10);
  frameRate(60);
  /* start oscP5*/
  oscP5 = new OscP5(this, portToListenTo);
  myRemoteLocation = new NetAddress(ipAddressToSendTo, portToSendTo);
  myBundle = new OscBundle();
  myMessage = new OscMessage("/");
void draw() {
  background(0);
  boolean send = false;
  if (key == 'q') {
    myMessage.setAddrPattern("/activeclip/video/position/jumptopointsofinterest");
    myMessage.add(0);
    myBundle.add(myMessage);
    myMessage.clear();
    send = true;
  if (key == 'Q') {
    myMessage.setAddrPattern("/activeclip/video/position/pointsofinterest");
    myMessage.add(0);
    myMessage.clear();
    send = true;
  if (key == 'w') {
    myMessage.add(1);
    myMessage.clear();
    send = true;
  if (key == 'W') {
    myMessage.add(1);
    myMessage.clear();
    send = true;
  /* send the bundle*/
  if (send) {
    oscP5.send(myBundle, myRemoteLocation);
  send = false;
  myBundle.clear();
Thanks for reading.
VJVertex
Re: Cue Points
Post by VJVertex »
sorry for my questions goto10... but you wrote "...solved in new release..., coming out Feb 1st."
Feb, 1st 2013 ? ;) is there a new release date?
Re: Cue Points
In my defense, I said 'slated for Feb 1st.' ;-)
We're very sorry, but some other bugs popped up that needed addressing, so it's going to be another week or two.
VJVertex
Re: Cue Points
Post by VJVertex »
thx, for the news and i´m looking forward to the end of feb. ;)
EDIT: time to test it! (4.0.1 out now) - i hope i works now - i love this feature :D
mowgli
Re: Cue Points
Post by mowgli »
Has this been resolved? I'm having issues mapping buttons to the cue points
