I've been freaking on making my own flash footage, and i want to make a motion tween that responds on the rparameters from resolume 2.0b.
My problem is following, (and I think that problems cause is in flash itself (not in an error of resolume 2.0b).)
When I have a timeline with a motion or shape tween and I use action command on let's say frame 20, then the playbacks halts there. But the rparameters keep responding. It just hangs on the specific frame where I implanted the action commands, like _yscale or _alpha, wheter i use _root or this doesn't matter.
I tried a lot of variations but i can't figure it out, any experienced flash programmers?
I would really be very very happy if I can use flash rparameter input while looping timelines (with motion or shapetween or both
Then i could make my own visualisation masks to layer over movie footage from my DV cam
Thanks a lot if anyone understands my problem and can give me the golden tip to proceed my work !!!
Cheers, Ruud
