hi,
i´ve installed, purchased and tested
resolume 2.0 beta now for 3 weeks. Everything works fine, fx and channel settings can be set to "audio input" control, settings are saved with the deck. That´s nice.
I´d be delighted, if you´d add a "save and recall" function in the global fx section too.
Thats really the only single thing I miss in this version: Global FX are very powerful, but in 2.0 beta version
all effects load in default mode, and the vj must always modify them to being musically controlled first, when
loading a new global effect.
This takes at least a few seconds - and it is visible in the mix. Besides that, it gets annoying after a while, to
repeat this procedure over and over again. Loading an effect through a keyboard shortcut works fine, but just the same loads only default fx settings.
Is there a workaround or did I miss something in the manual?
That´s the only thing that doesn´t seem pro / practical to me in resolume 2.0.
besides that ... cheers ... and greetings, george din
new global effects load w/ "default" settings
george din_
