audio from out-laptop-source
noxxx_
Post by noxxx_ »
hi
how to capture sound parameters on resolume 2 from an external source?
i can do that running winamp.
tnx
bowser_
Post by bowser_ »
why not just use the audio-in plug and configure your system's audio mixer settings to record line in... i guess...
noxxx_
Post by noxxx_ »
ok...but recording input sound means taking space on hard disk...isn't it?
levon_
Post by levon_ »
no, you tell windows to use that input as the recording channel, that means it sends that input to any app that wants access to it.
noxxx_
Post by noxxx_ »
ok, i'll try...tnx
and let u know in case of troubles
noxxx_
Post by noxxx_ »
ok, i'll try...tnx
Danger_
Post by Danger_ »
can anyone tell where we tell windows to use that input as the recording channel ?!
noxxx_
Post by noxxx_ »
right...and not to record on hard disk ..
can anyone tell us?
Danger_
Post by Danger_ »
once i pass by a plugin for winamp that maybe do that....
bookmark's bookmark's where are they :P
[The extension swf has been deactivated and can no longer be displayed.]
themadhatter_
Post by themadhatter_ »
1) doubleclick on the small volume-symbol at the lower right corner
2) some kind of mixer settings should appear
3) click on options --> settings
4) there u should be able to choose between playback & record
5) select RECORD
6) now click the wanted options to select their checkbboxes... (eg. LINE IN)
maybe the options will have different names/terms on your system, because i dont have installed windows in english... anyway, if u want to do it - u will figure it all out by yourself!
have fun,
themadhatter
