Midi Problems
jjm35
Midi Problems
Post by jjm35 »
On Friday we had a performance with my funk band, which used a projection of audiovisual material and eight live cameras. The whole show was pre-programmed song-by-song into a MIDI sequencer, and launched through an internal midi port (LoopBe1) to Resolume.
For this, I had previously used Arkaos GrandVJ without problems, but I wanted to migrate to Resolume, becouse it gives me more features for what I need. The problem is that even Resolume works perfectly with a midi controller (Behringer BCR2000), it ignores randomly some of the commands midi CC # that I send in the sequence through the internal midi port (LoopBE1). It's really strange: on a fresh start of Resolume, it works perfectly, but when you take two or three sequences, it starts to ignore midi commands and not working properly.
The result is that I had to quickly re-program the entire show for my Friday gig on Arkaos again :(
Well, I WANT to use Resolume for my show, I get much better and professional results becouse I can use custom masks for the live cameras, and I can stack some effects togheter (features absent on Arkaos). Only this two things gives to my visuals more professional look that Arkaos, but I NEED that Relolume can work smoothly with CC# midi commands that come through a internal midi port (some internal midi port, I do not care which one -until now I was using LoopBE1, but I would can use some other-)
Any suggestions?
Thank you
