because QuickTime Player does not support file drag,Difficult to use.
Once I use Potplayer play MJPG file, but Potplayer not support DXV encoded file.
please recommend a better player,support file drag and coded view.
thanks all
Please recommend a player support for-DXV
Re: Please recommend a player support for-DXV
Thanks homing
But I cant't play the file with DXV,what am i missing?
Thanks again.
If you use Windows...unpack the attached file and copy it to this Folder:
C:\Program Files (x86)\QuickTime\QTSystem
Your Quicktimeplayer should now play DXV Files
Greetz
Greetz
- Attachments
- DXVWindows.rar
- (18.2 KiB) Downloaded 637 times
Thank you very much.cosmowe wrote:If you use Windows...unpack the attached file and copy it to this Folder:
Greetz
I use win7,Quicktimeplayer can successfully play DXV file。
But I don't like Quicktimeplayer,It is not enough Convenient, do not even support drag and drop files/code view/Automatically load the similar file/Fixed window size....
What player do you use?
Thanks again
