bpm counter going crazy!
VJair
Post by VJair »
in 4.0.1 on pc ( win 7 64 bit ) - sometimes when i turn avenue on, the little 4 part meter that shows which beat avenue is on ( to the right of tap / resync / pause ) goes MENTAL!!!
currently the bpm reader says 120 bpm, but the indicator is moving MUCH fatser - maybe 4 times as fast ( its hard to tell ) id does several "laps" per second.
anyone else experienced this? it actualy makes avenue completely unusable for bpm synced clips ( of which i have many! )
a reboot of avenue sometimes ( but not always ) fixes it - nothing other seems to work ( tried new comp / turning off all midi / ect )
Basic
Re: bpm counter going crazy!
Post by Basic »
still having this problem? - did you have anything connected? Ableton or anything?
HerrNieDa
Post by HerrNieDa »
normal u must select a working soundcard in the audio preferences to get the bpm counter to work.
maybe this is the problem!? try to delete the preferences.xml file from your resolume documents folder ;)
