Lemur (Ipad) OSC Interface
HerrNieDa
Post by HerrNieDa »
i just finished my base-Interface for my Lemur for Ipad!
Hope it is usefull (and bugless ;) ).
If the Controls won't fit for you, it's hopefully a good base for your own layout!
if someone else is patching some extras it would be nice to share the work.
Lemur is a really cool tool but it takes some time to get all things set up. I think this should help many people getting started and should save much time!
Suggestions are very welcome ;)
have fun with it ;)
Edit: it's only osc adressed, midi is not configured, maybe someone has an idea for a good midi-adressing!? (maybe which works with edirol v4 and ableton standard settings for example).
maybe a popup window with v4 midi controls would be nice in the resolume interface...
and so many other cool things are possible with lemur, some usefull features from the standard-presets also should be implemented to improve the interface, and so on .... :ugeek:
UPDATE: now 3 Screens, Lemur Interface is full anyhow, maybe 1 extra Button is left to configure ;)
ipad resolume superneu.jzml 4.zip
V 4.12
(46.46 KiB) Downloaded 1295 times
ipad resolume 3screens.jzml.zip
V 3.0
(22.76 KiB) Downloaded 1052 times
ipad resolume 2screens.jzml.zip
V 2.01
(20.18 KiB) Downloaded 901 times
Re: Lemur (Ipad) OSC Interface
:) Looks already great on the Jazzeditor of my Lemur...looking forward to test it with the FruitPad.
Greetz
HerrNieDa
Post by HerrNieDa »
Update! :idea:
HerrNieDa
Post by HerrNieDa »
Update, new interface!
the old ones are more buggy ;)
new one should also be handier :)
vj granda
Post by vj granda »
Thanks a lot for share it HerrNieDa....
HerrNieDa
Update
Post by HerrNieDa »
fixed Dashboard Attributes and moved speed/scratch to the fx container.
did't tested it live yet, but i think it's getting better :)
Your New Lemur Layout is great...much much much better than the first!....
greetz
dirtyjohn_lv
Post by dirtyjohn_lv »
Had an accident with my old ipad, went out and bought the new one and the layers/clips container is blank. Nothing in it at all. Looks fine inside the editor. Maybe it has something to do with new resolution?
EDIT:
Just found out from some testing, that there is a difference between the iphone and ipad apps for lemur maybe?
The same component (with scripting) on the iphone layout will receive OSC from Arena fine, but not send properly, but on the ipad it's the opposite (will send properly, but not receive).
HerrNieDa
Post by HerrNieDa »
you need version 3.03
before you could only use 512kb interfaces, now it's up to 2MB....
