Uninstall Resolume 2 beta 1 and tryout
djdiego71
Post by djdiego71 »
When uninstall beta 1 and install beta 2 cant try the soft, the time to trial reset to zero day (i have 10 day left to tryout yet)
Why??????
snif!
levon
Post by levon »
i think its to stop people from unistalling and re instaling it when the trial runs out.
no uninstall required!
ppleae note that you can run all version of resolume next to eachother! you do not need to uninstall any veersion because they all have different install folders.
djdiego71
And now?
Post by djdiego71 »
Ok, when installing the new version, i see the new folder, but can't run.
trial has expired. I cant try the new version.
[Edited on 9-10-2004 by djdiego71]
pxl
Post by pxl »
i'm having the same problem... nothing i can do about that?? :(
[Edited on 10-10-2004 by pxl]
Trunx
Post by Trunx »
yep, we've all had this problem. I'm guessing R2B2 references the same regristry entry regarding the time limit as R2B1 therefore making it think that all the tryout time has expired.
seex
Post by seex »
same with me, the beta version was jumping to four days when it came to one day left, i didnt do any uninstall and just instaled the beta 2 but i culd not run the programe since it was showing try period expired from the first day.
