Normal activity monitor levels/temp?
Ponyboy
Post by Ponyboy »
Hey guys,
I'm running a Macbook Pro for work. Its a 2.33 core 2 duo with 2 GB of ram.
I notice that my activity monitor is taking 85-90% of the CPU. Sometimes it goes up over 100% (that's just with Avenue open and nothing else!). Meanwhile SMC control tells me it's running at about 70 degrees (150 F) Celsius.
Any thoughts or suggestions on how to improve this other than upping the RAM?
vedder
Re: Normal activity monitor levels/temp?
Post by vedder »
hi ponyboy,
if you look at the activity monitor, is avenue uses your resources?
usage.tiff
usage.tiff (48.17 KiB) Viewed 9646 times
mac pro / 2 x 2.93 6 core / 48 GB RAM / ATI HD5770 1 GB /
Ponyboy
Post by Ponyboy »
I think this shows you what's happening. :?
Screen shot 2012-04-04 at 12.02.14 PM.png (20.5 KiB) Viewed 9633 times
Screen shot 2012-04-04 at 12.01.22 PM.png (162.71 KiB) Viewed 9633 times
Ponyboy
Post by Ponyboy »
I should clarify... the above images show Avenue/Resolume open. And that's literally all it's doing. It's not playing any clips or anything.
HerrNieDa
Post by HerrNieDa »
very strange indeed....
on my mbp with 2,2ghz core2duo i don't get more than 30% (doing nothing) to 60% (playing some layers with effects, no outputscreen) cpu usage, so there is just 1/3 cpu power used.
which OSX version you have? (here i have 10.6.8)
since 10.6 osx should handle multi core cpu's better, so maybe thats a hint ;)
i have installed Fan Control, here you can adjust the Fan Speed and Temperature-Low/High, maybe helps a bit with your Temperature ;)
but it's not normal that the cpu is used that heavy.
any other special hardware attached?
maybe try to delete the resolume preferences files in your document folder... perhaps somethink went wrong here!?
maybe try to start resolume and locate the logfile and send it to the resolume team.
I also got CPU Performance Problems, but i think it's the CPU :D
it's an Socket 939 AMD X2 4200+ or so .... he gets nearly full loaded (over 90% on both cores!) when playing some layers and effects :D this happened in windows xp... maybe win7 runs better!
Ponyboy
Post by Ponyboy »
I didn't think it was normal either... but considering that it's a "work" laptop, God knows what's been done to it ;) Although I would rather the program run more efficiently. I've noticed a very slight "lag" or skipping if you will on some of the video clips I've tried to output to the projector (the only hardware hooked up the laptop). Running 10.6.6 on it (I think that's SnowLeopard). Hmm... :?
Ponyboy
Post by Ponyboy »
Bump.
Turns out the laptop is a bit older than I thought... a 2007 model. It can only take 3gb of RAM (max)... so I'll be replacing one of the 1gb with a 2gb stick later in the week and hope that helps some. I told my boss that ideally I should be running 6-8 gb of RAM for this software. We'll see if we end up getting a new computer eh ;)
