Searching for: a mini DVI&VGA seamless switcher HD
I'm looking for a a mini DVI&VGA seamless switcher which supports HD resolution.
2x DVI-I IN 1x DVI-I OUT
Does anybody know such a tool?... I know there are some nice little boxes from TVONE...but they cost round a bound 800€...I'm searching for something for round a bound 400€.
hopeful greetz....
Basic
Re: Searching for: a mini DVI&VGA seamless switcher HD
Post by Basic »
Hey Cosmowe,
Ah i was going to suggest the TVone boxes as ive used them and they are great. I used iMixHD too. how often will you be using it?
what will the sources going into the mixer be?
Cheers
Basic
Hey Basic,
I want to use this switcher on every job in future. Just to switch between main and backup system.
If you mean the switcher.... iPad, PC, Mac, Netbook....
greetz
