more midi weirdness
mowgli
more midi weirdness
Post by mowgli »
When I map a knob of my BCR to the composition volume it only works if I have midi feedback disabled in Resolume's preferences, otherwise the values jump randomly between a small range!
Re: more midi weirdness
This is the same bug as reported elsewhere on the forum. The ranges for midi output are not set correctly, and this is fixed on the upcoming 4.1 release.
mowgli
Post by mowgli »
In case you're unaware , this is happening with the transition time sliders too
