Source artifacts
dirtyjohn_lv
Source artifacts
Post by dirtyjohn_lv »
I use sources, a LOT.
The line sources keep causing small issues. In the image, you can see one of the line sources has artifacts in the thumbnail. I used to think this had something to do with IR Workshop plugins, but this is a new composition with only native effects applied.
Every time I open my composition, nothing will play in the main output until I click preview for one of the line sources. Then the main output appears.
This happens for any deck I have a line source in. If I switch to a deck with a line source, main output goes black until I preview the line. As soon as I switch to a deck with normal video, everything works as expected.
Doesn't bother me that much, as I mainly use the sources to drive the beginning of a show until video is needed.
Frame rate also drops a LOT when layering 3 or more sources. Could be my machine, not sure
Re: Source artifacts
That thumbnail looks pretty cool actually.
Could you clear the thumbnail cache , and contact us with your logfile if the problem persists?
Mac: /Users/[username]/Library/Application Support/Resolume Avenue 4/
PC: C:\Documents and Settings\[username]\Application Data\Resolume Avenue 4\
Win7: C:\Users\[username]\AppData\Roaming\Resolume Avenue 4\
