let's dream:
Vectrex emulation in Resolume...
AlexEtJeremy
the audio fft values are send to any flash file you play in resolume. you could make some fancy flash animations with this.
script flash files to use the audio values.
You could make freeframe plugins that respond to the audio. but there is no way yet to send audio data to the plugin (except for the parameters, but they are limited of course).
You could build in audio analysis into your freeframe plugin, the problem is that every plugin would have it's own audio analysis and that doesn't help performance.
so cook up some flash file and see what you can do.
[Edited on 15-10-2004 by edwin]
AlexEtJeremy
