Blurry output.
Designerpig
Blurry output.
Hey, ive got a problem, my laptop has 4 GB ram, an Intel Core i7-2670QM 2.20 Ghz processor, tha loop on the picture is 1280 x 720 AVI, and im useung Resolume 4.0.0 on Win 7 64 bit with 1280 x 720 resolution, so pearhaps the problem is that my laptop isnt strong enough for such high resolution. Anyway, im haveing those white blurry stipes all the time on the output, and i cant help it. Pls help
- Attachments
- Névtelen.png (55.2 KiB) Viewed 3999 times
Re: Blurry output.
Hello Designerpig,
It seems to me an interlaced artifact. You can try to deinterlace your footage.
It's strange you are on 4.0.0...
Designerpig
Re: Blurry output.
Thanks for the assist, i've got it fixed.
