Slideshow Folder
funkyant
Slideshow Folder
Post by funkyant »
I would love to have a plugin, or be able to assign a clip slot to a folder path which uses jpg, bmp, png, etc in that folder to create a slideshow, in a similar way to the simple desktop slideshows in Windows 7.
I remember in Resolume 2 you could drag multiple stills into a clip slot to create a primitive slideshow, but it seems that functionality has been lost, no?
Anyway a folder path would be much more useful, as any changes made to the folder contents would update the slideshow.
I think this could be very useful in a lot of interesting ways.
LOVING all the improvements happening to Resolume. Keep up the great work guys :)
Basic
Re: Slideshow Folder
Post by Basic »
I know this would be a pain but could you use the auto pilot function and put a single frame into each coloum/layer
or do it simply in AE.
But, i do understand what you mean, those are possible alternatives but requires some production for the second one. I didnt realise you couldnt have this functionailty, I haven't done a slide show since Res 2.3 :)
Basic
Post by Basic »
I did just see this thread actually. It may be useful?
viewtopic.php?f=14&t=9544
its flash based.
mowgli
Post by mowgli »
this is easily done with Quartz composer too and you can have a bunch of different transitions to select from too.
