[fixed] TouchOSC Autotun Command issue
digitalgigalow
I have an interesting question. Are the auto run buttons set as trigger buttons or toggle buttons. I Have tried to to setup the auto run buttons as trigger buttons and they jump. when I push any outrun button first and everything is good. when I press the next button it doe the action for a second then jumps back to the previous action. Toggle works good, yet after I push the button, i have to push it again before i can choose a different button. This is ok, but it would be nice if they were set up like the clip trigger.
Re: TouchOSC Autotun Command issue
Outrun?
If you're talking about the autopilot, the four buttons can be addressed via the same OSC address (/activelayer/autopilot/action), and then sending an integer of 0 to 3 for each button (0 for previous action, 1 for pause, 2 for next action, 3 for random action).
Does that answer your question?
digitalgigalow
I think I understand. I will have to play with it. should I use a toggle or push button?
thanks for the quick reply.
digitalgigalow
The problem has been rectified, although If you look at the buttons on Resolume GUI, the integers I came up with are as follows: 1 = left button, 3 = pause or stop. 0 = right button. 2 = RR button. Also when creating layout in TouchOSC these buttons integers will have 2 boxes for the integers (first box through to other box). both boxes should have the same number. This is why I had jumping. push button is what i and creates want.
ALL IS GOOD IN THE HOOD!!!!!! At least for Resolume. Now to learn the midi option in TouchOSC so I can control Ableton Live 7 w/a Bento-San 4-Channel Smart-Mixer Setup.
