ATI Radeon 6870 crashing Avenue
j5garrard
Post by j5garrard »
I just put in a new Radeon 6870 into my Mac Pro, and while most apps run great, e.g. After Effects, Avenue will not launch. Same result with Mac OS versions 10.7.4 and 10.8.
Any suggestions to remedy this? other than getting a different video card of course, which may be the only answer.
Thanks,
Jeff
Austin, TX
Basic
Re: ATI Radeon 6870 crashing Avenue
Post by Basic »
Hey Jeff,
Have you had any luck in getting this sorted?
Cheers
Basic
j5garrard
Post by j5garrard »
No - haven't found a solution. I'll be sending the card back and looking for another. Any suggestions?
Basic
Post by Basic »
no unfortunatley i was searching the forum and vjforums before but GFX arent my strong point. I hope you get sorted.
have you tired all the usual updating etc?
As far as I know, the 6870 is not officially supported by Apple yet, so you'll have to wait until they release drivers for it.
Shorties
Post by Shorties »
I have an ATI Radeon 6870 (XFX 2GB) in my hackintosh and haven't had any issues with Resolume (On both 10.7 and now 10.8), are you sure there isn't something else running that is interfering and could be causing Resolume to crash? I'm pretty sure I am using the native ATI6000Controller.kext as my graphics driver that came with mountain lion, so I imagine the 6870 should work on a Mac Pro as well.
kmifflin
Post by kmifflin »
When I every have a funky problem with Resolume I find trashing the preference files Located in your Documents helps every time.
j5garrard
Post by j5garrard »
Appreciate the help from everyone here. I switched to an nVidia 8800 card and all apps run fine.
