When there are more than one flash clip playing at same time with images into swf archive, playback fps drop dramatically but only on flash clips, not on other video formats that are playing in others layers. The fps counter not notice of this low playback, keep the rate of other clips (avi, mov, live cams).
Is not ever but occur many times.
Composition is 640x960 (2 layers at 640x480 one up, other down) every layer out on one video output only.
FPS rate are from 55 to 45.
Flash playback issue
- Attachments
- flash examples.zip
- (360.99 KiB) Downloaded 574 times
Re: Flash playback issue
No one can tell me if the problem is in the files or in flash decode or resolume?
Please, because I need to use flash for advertising inside the club, no VJing.
Most likely the issue is that your Flash files have to read too much data, so they get choked. Try it with lower resolution images, or loading less often.
Really? All images are at size played on screen, (less than 640 x 480, jpg compress).
After try some others flash files, solution is not available. Many other flash movies use only vectors, and same problem occur. A unique swf file playback on the composition not affect, but 2 swf playing at same time has a very deep fps drop. In some cases, make Avenue unresponsive until unload any swf file from layers. And this issue is in many different CPU configurations.
