intensity pro upside down
mowgli
Post by mowgli »
I've just installed and intensity pro capture card and it worked instantly which is great but my capture appears mirror reversed both vertically and horizontally. Any clues as to why or how to resolve it?
Re: intensity pro upside down
Does this also happen with the BM capture software?
4eyes
Post by 4eyes »
Same issue. Retina MBP with Intensity Shuttle Thunderbolt. Not a huge deal to flip but potentially embarrassing if yer in a rush and forget to do it! ;)
So does it also happen with the BM capture software or not?
mowgli
Post by mowgli »
I didn't get a chance to try it with capture software and i don't have access to the macine in question anymore!
4eyes
Post by 4eyes »
Will test it when back in the office this evening.
ryan
Post by ryan »
Intensity Pro's Capture Software(Blackmagic Media Express) displays the video normally.
Running on MacPro OSX10.8.2
Arena 4.1.2 sees it upside down. Fix anyone?
Warspite
Post by Warspite »
Need to rotate 180 degrees on x or y axis (do not remember which one) on Macbook Pro + Intensity for Thunderbolt and UltraStudio Express. Tested composite input.
Everything ok on: PC/Win7/Gigabyte MB with 2 Thunderbolts/Intensity for Thunderbolt and UltraStudio Express. Tested HDMI input.
Do you reckon it's possible that you guys could test if there's a difference between the composite and HDMI inputs on the Mac side of things?
Warspite
Post by Warspite »
Just tested composite input with intesity shuttle for thunderbolt on PC - same as hdmi - no need to rotate.
Tested HDMI and composite input on Mac - need to rotate 180 degrees on X axis.
