Flash Player 11 causes Resolume crashes on Mac OS X
Flash player 11 causes Resolume crashes on Mac OS X. If you install flash player 10.3 it all works fine.
Here is how to uninstall:
http://helpx.adobe.com/flash-player/kb/ ... ac-os.html
Download Flash version 10.3 here:
http://helpx.adobe.com/flash-player/kb/ ... sions.html
Do not use Chrome when you uninstall and install because Chrome uses it's own Flash player system.
Update: flash version 10.3, not 10.4 :?
rpacker
Re: Flash Player 11 causes Resolume crashes on Mac OS X
Post by rpacker »
Not sure if I am blind but I can't find Flash Player 10.4 for the Mac, nor a link, on the Flash archives page.
Mac Pro 8-core, 14 Gb ram, ATI Radeon 5770 graphics card, AJA Kona Lhe
vj granda
Post by vj granda »
Same here...
I'm sorry you're right 10.4 does not exist, the latest working version is Flash Player 10.3.183.25.
rpacker
Post by rpacker »
bart wrote:I'm sorry you're right 10.4 does not exist, the latest working version is Flash Player 10.3.183.25.
I did see that particular version of Flash, but not for the Mac, they seemed to be all executable PC files. Can you possibly provide a link directly to the Mac download for the appropriate version of Flash. Much appreciated!
The zip file that is linked to on that page contains both PC and Mac installers. The Mac installer is the flashplayer10_3r183_23_mac_intel.dmg file. We cannot provide links to files directly, since redistributing Adobe software is not allowed. :?
rpacker
Post by rpacker »
goto10 wrote:The zip file that is linked to on that page contains both PC and Mac installers. The Mac installer is the flashplayer10_3r183_23_mac_intel.dmg file. We cannot provide links to files directly, since redistributing Adobe software is not allowed. :?
I am still not finding the Mac installer for the flashplayer version 10.3 as you point it.
I just uploaded an attached screen shot that shows only PC .exe files in the download folder for 10.3.183.25.
flash player.png (115.4 KiB) Viewed 19866 times
Ah yes, the latest 10.3 version for Mac is 10_3r183_23 (not 25).
