Problem preference option (general)
SystemD
Post by SystemD »
capture ecran resolume bug.png (139.86 KiB) Viewed 7115 times
Configuration :
MacBook 1 (Ableton Live) --- Midi over LAN ---> MacBook 2 (Resolume)
When I clic on this button, it doesn't change anything. the clip pannel change as soon as Ableton plays a different Midi note.
Anyone as the same problem or it's me?
Thanks !
version Arena 4.1.2
Snow Leopard
Re: Problem preference option (general)
It should work like this: When the button is checked, the panel will update. When it is *not* checked, the panel won't update. Maybe you got the behaviour the other way around?
SystemD
Post by SystemD »
this is what I like so. but if I check the box or not, it produces the same result: the panel is updated.
Strangely enough, it is working for me on both Lion and SnowLeo computers. Can you delete the config.xml file and see if that helps?
SystemD
Post by SystemD »
I made new tests with my students during a week of training on the software Resolume 4. Today the day was dedicated to the synchronization-Resolume Ableton. Here are some things that can interest you:
- We could test different configurations and PC machines (Vista) PC (Win7), Mac OSX 10.5, 10.6 and 10.8
- I still have the same problem with the update panel on my machine (OSX 10.6), but it works on machines 10.5 & 10.8. (Ableton Resolume and are on the same machine connected via the bus IAC). On my machine, I had previously deleted the file config.xml.
- We connected the two PCs (one for Resolume and the other with Ableton) in MIDI interface with 2 MIDI-USB. We encounter the same problem with the update panel.
- Resolume Avenue 4 & Arena crash at startup on OSX 10.5. But Resolume 3 works
- No problem for stability, Resolume works like a charm during this week !
Tomorrow we do a day dedicated to synchronization Resolume DMX. If I have time, I'll try to make a return of our findings.
SystemD
Post by SystemD »
Today we've made some test with Arena & DMX.
Works great :)
But maybe something is missing : color are controlling in RGB mode.
A CMYK mode could be great when you have automatic lignt projector like Mac 700 on stage.
SystemD
Post by SystemD »
Does anybody has those problems with the panel update ?
