Is Mac Mini 2012 enough to run Resolume Avenue/Arena?
etherealgypsy
Post by etherealgypsy »
Is Mac Mini 2012 enough to run Resolume Avenue/Arena? It will solely run on VJing, the specs of the new Mac Mini 2012 is as follows:
Processor: 2.5 GHz Intel Core i5
RAM: 8 GB SDRAM
Hard Drive: 5 cessor: Intel HD Graphics 3000 processor
Operating System: Mac OS X Mountain Lion
I think the main question is, is the video card Intel HD Graphics 3000 sufficient to run both of the resolume programs with dual monitor? for live performance I intend to use the old Macbook 13.3 (Core 2 Duo, NVIDIA GeForce 9400M 256MB DDR3 Graphics Memory) as I don't have the budget yet to purchase a new lappy.
Cheers! :)
lerabot
Re: Is Mac Mini 2012 enough to run Resolume Avenue/Arena?
Post by lerabot »
I use the higher end mac-mini (not the server one) and it works perfectly with avenue.
I often use multiple layer of 1024 x 768 video, hi rez stills. without a problem, with dual monitors.
HerrNieDa
Post by HerrNieDa »
there should be also mac mini's with amd radeon 6630... new ones should have 7730... ans seems it's the server version
don't know if it runs on the internal i5 gpu
skulpture
Post by skulpture »
I just did a little test...
All details here:
http://vjforums.com/showthread.php?t=38744&page=2
