I have a show tomorrow and they wanted to load a live website, i do not have any input device like a blackmagic intensity to capture from a other PC and load it into Resolume 4, i was wondering and hoping there is a Syphon plugin or something where i can load the page on the local PC / Mac where Resolume is installed and show it on a layer.
They will also play some slides but i could get them out of power point into Resolume 4...
Need some help
Need some help
Re: Need some help
how do you mean? live? are they wanting to be able to show it as a user clicks away?
Re: Need some help
They have a website that shows tweets with animations and things like that. Plus later they are going to explain some things on the web.
All my mixing is going through Resolume it became my video switcher / mixer. The only other option i could find is a software called vMix which does a remote desktop connection for me. But then i cant use Resolume.
theLABVisuals
Re: Need some help
If your looking for a way to display tweets etc. then have a look at https://vimeo.com/34447356.
deepvisual
Re: Need some help
syphon virtual screen
https://rapidshare.com/files/3975409114 ... Screen.pkg
go fullscreen on chrome and problem solved.
Re: Need some help
Thank you so much... I solved it with vMix since the event was 5 hours ago, but i will use this from now on... Great thank you so much... Where is the development link for this so i keep updated on it.
deepvisual
