Mark multiple colums - delete/copy
Hello Resolumes,
I think that the subject says it clear ;)
It would be very handy if marking multiple colums to delete or copy copy them would be possible.
Greetz
Tschoepler
Re: Mark multiple colums - delete/copy
Post by Tschoepler »
Acutally, this does work for me. Just shift select from top to bottom or the other way around > cmd + x/c > cmd + v and you should be fine. But be aware that it overwrites any existing clips in the new place. Hence, I think it would be great if it was possible to drag and drop multiple clips at once, thus any existing clips get moved to the »old« slots. This behavior is already accomplished for one-file-dragging.
And of course this feature has been requested before here.
fulleffekt wrote:Multiple clip drag.
