New Resolume on the way?
mrfipe
Post by mrfipe »
Resolume guys are so queit, no updates, nothing... Is there a new version on the way?
3Media servers i7 860 8GB RAM 240GB SSD Nvidia 760
1Media server i7 7800X 16GB RAM 240GB SSD Nvidia 1080
1Media server dual Xeon E5 2650 V2 32GB RAM 240GB SSD Nvidia 1080 + 970
1MacBook Pro 15 Retina i7 16GB RAM 512GB SSD Nvidia 750
He2neg
Re: New Resolume on the way?
Post by He2neg »
there is allways a new version on the way.... but as long as no bug need to be fixed... why should be updates every week.
Clam down and be happy as long as you have a good version ...
~Berlin~
drazkers
Post by drazkers »
http://resolume.com/blog/
doesn't seem that quiet. Maybe give it a browse?
We know we talk about Res 5 a lot, but that's still a long ways away. We still have many plans for Res 4. We are working on Resolume every day. There are always bugs to fix and things to improve. The last week we've been focussing on improving SMPTE playback.
We're only at 4.1.11 now. What do you guys think is going to be new in Res 4.2.0?
pfelberg
Post by pfelberg »
- Smooth playback concerning horizontal scrolling images;
- Copy paste clip attributes or capability of editing all clips (in a deck) attributes at once;
- Zoom in advanced display. ; )
SystemD
Post by SystemD »
- create groups for effects with the possibility to save them
- duration in seconds for parameters (not only from 0.00 to 1.00)
- rename columns
mrfipe
Post by mrfipe »
I would like to see advanced input options in advanced output,
like ability to do triangles a circles, and of course corner pin the quads. :)
fruitygreen
Particle from layer
Post by fruitygreen »
I would like particle from layers.
:P Thank you
ReggieUnderground
Post by ReggieUnderground »
Joris wrote: What do you guys think is going to be new in Res 4.2.0?
Better handling of deck names in compositions with many decks, such as an option to never truncate the names.
machfox
Post by machfox »
SystemD wrote:- create groups for effects with the possibility to save them
- rename columns
+1 for group effects.
I really need option to rename effects or at very least group them together - so the ones I need/use are available quickly.
