Hi fellow Resolume Flashers ...
I saw someone was looking for this on another thread, and I was thinking of posting it anyway, so here it is.
A simple multiline Flash Text SWF I made for use with Resolume. It has a range of text formatting parameters (font size, Y position, leading, L & R margins, alignment (left, centre, right, justify), and white\black text toggle). Uses a clean sans-serif font.
Use a # character to force line breaks. The SWF will convert these to newline characters before displaying.Obviously you can't paste multiline text into Resolume as Resolume will only pass a single line at a time to the SWF.
It's 640x360 which will scale up to 1920x1080 or any other 16:9 size perfectly. Make sure you set the size of the clip to your composition size for maximum smoothness.
Text has a slight drop shadow so you don't need to worry too much about it disappearing.
Offered for your use without any warranty or guarantee, but I hope you find it useful.
I'm not a seasoned Flash coder so if anyone spots any possible improvements let me know.
Cheers
Richard
Freebie: Multiline Flash Text with Formatting
craftycurate
- Attachments
- MultiLineText.zip
- (43.55 KiB) Downloaded 3260 times
AdevProjects
Re: Freebie: Multiline Flash Text with Formatting
Awesome love it
Thanks for sharing. This is a really useful swf.
Pretty good Richard, I will try it right now.
Just a tip, what about using another character to break lines?
(so you can type and show a hashtag on screen).
Hi craftycurate,
for me this flash file doesn't work...hmm...when I drag'n'drop it into a clipdeck the field stays blank.
Win 7 / R.4.2.1
Greetings
Win 7 / R.4.2.1
Greetings
Do you like outlines? Easy Outliner on Juicebar -
AdevProjects
Make sure you have flash player installed for internet explorer?
craftycurate
Ok here's one that uses the tilde (~) char as the newline delimiter.
- Attachments
- MultiLine2.zip
- (43.54 KiB) Downloaded 2142 times
Thanks crafty.
Is a pretty useful little tool, and works great.
Cool! Thank you!
is there some how a way to use a google spredsheet as datasource for the text field?
craftycurate
Not in the current version. Loading text from an external source would definitely be useful. I might give it a go at some point but it won't be any time soon. If I do, I'll post it here
wow! Cool! thnx!
