OSC - touchOSC not working aniymore on Res 6?
thomgee
Post by thomgee »
I try touchOSC on Resolume Arena 6
It was still running on Res Arena 5 but now on 6 no chance.
any idea?
or am i missing a thing
Re: OSC - touchOSC not working aniymore on Res 6?
Yes, the OSC addresses have changed in Resolume 6, so you'll have to update them.
thomgee
Post by thomgee »
Zoltán wrote:Yes, the OSC addresses have changed in Resolume 6, so you'll have to update them.
OMGosh... why that?
is there a manual or tut about?
or at least - where/how do i get the adresses?
Arena 6 & 7
MacOS 10.14.4 Mojave
Macbook Pro 2017
3.1Ghz | 16 Gb | Radeon 560 4GB
Edwin posted posted a description of the new OSC features here : viewtopic.php?f=5&t=15135#p63822
You can get the OSC addresses going into OSC shortcut editing, in Shortcuts menu, and clicking on one of the highlighted GUI items. You'll see the addresses in the shortcuts panel.
Vjcheshire
Post by Vjcheshire »
So I'm re-mapping my Ipad TouchOSC for Resolume 6 as it seems some clients still like "vibe" of being able to walk around and do visuals. Running into some problems with the Clip Properties, specifically Clip: playdirection, playmode, playmodeaway, and Speed. Tried a few different variations of
/composition/selectedclip/transport/position/behaviour/playdirection
/composition/selectedclip/clip/position/behaviour/playdirection
/composition/selectedclip/clip/behaviour/playdirection
/composition/selectedclip/behaviour/playdirection
and
/composition/layers/1/clips/1/transport/position/behaviour/playdirection
as well as messed with the ints. 0-1, 0-2, 0-3..
and none of them seem to work. Everything else so far has worked great. Any suggestions?
work fine for me.
Check what input you get in Resolume in Preferences OSC inspector.
Vjcheshire
Interesting the address is sending out blank. Odd.
Vjcheshire wrote:Interesting the address is sending out blank. Odd.
Could be too long for touchOSC to handle.
There was an issue like this in another thread.
Grimm90
Post by Grimm90 »
I'm also having issues. I see the osc messages coming in the resolume 6 preferences window , if you expand it , but i cannot "map" anything .
So i'm going shortcuts , edit osc , all is redish , i see the command coming in the preferences window , but nothing gets linked. I stop mapping , the control doesnt react.
Midi bridge on the touchosc does run so i'm pretty sure its not the network or a firewall or anything like that ?
Grimm90
Post by Grimm90 »
i tried this template viewtopic.php?f=12&t=15555&hilit=touchosc&start=10
works fine , i see my faders move & i can select clips .
So it's just the OSC learn function that isn't working ?
Correct me if im wrong but in resolume 5 i could just select a parameter , move a virtual knob on touchosc and it was linked , just like my midi controller ?
