Layer like a mask in a advanced output layer
AnveG
Post by AnveG »
Hi Guys,
I want use a layer in my composition like a mask over other layer. If i make my output with composition layer it's all ok. If i want compose my output with multi layer but if a use a layer like a mask this layer don't mask the other layer....
How i can do this?
Re: Layer like a mask in a advanced output layer
If I understand you correctly, setting the layer masking mode to All below should do the trick.
AnveG
Post by AnveG »
I want use this setting for one layer over the other in advanced output
Schermata 2017-11-14 alle 15.16.43.png (31.55 KiB) Viewed 4223 times
Oh, ok, you are using Resolume 5.
Advanced output doesn't have blend modes, the slices are simply displayed on top of eachother.
Do you need your (layers routed to) slices masked individually with the same video clip at different locations in the output?
Layer Routing is seriously the worst idea we ever had. And I've done some stupid stuff in my day.
