codec regression
CHOURAQUI
codec regression
Post by CHOURAQUI »
I use to be able to import vids made with FRAPS in preceding versions (codec is FRAPS FPS1)
it is not support anymore in version 6
Re: codec regression
Could you upload one smaller recording, so we can take a look?
CHOURAQUI
Post by CHOURAQUI »
which email to send you short vid example via wetranfer ?
you can use mail@resolume.com
CHOURAQUI
Post by CHOURAQUI »
small example via wetransfer in a few minutes on this mail address thanks
Had a look at the file, for me it's not playing in Resolume 5 either.
Without qiucktime installed it won't even load, with quicktime it displays as white.
Trying to play the file in qiucktime directly, qiucktime tells me to download some additional component for which the link is broken on the apple website.
I tried to play the file in windows media player also without any luck.
So yeah...
Resolume 6 doesn't use quicktime as playback engine any more, but as it looks, even if it would you can't get the component needed from apple any more.
It's not easy to say this, but I think you need to look for an alternative screen capture program, or choose a different codec for encoding the video if you need to use the videos in resolume (or windows) directly.
H264 should work for example in Resolume 6, not sure if Fraps has support for it.
francoe
Post by francoe »
Fact is fps1 is a propietary codec, just for windows (there's not such thing as quicktime component for it).
Maybe that's related to ffmpeg, and his legal ability to deal with propietary codecs. Can't think a way to play with that on resolume side.
CHOURAQUI
Post by CHOURAQUI »
I can't play it in quicktime anyway, but was and am still able able to use them in any resolume version until 6.
