Controlling Speed with MIDI controller on ALL clips on a Layer
eloi.maduell
Post by eloi.maduell »
hi resolume's !
I've a question, possibly it's so simple, I've tried to look for information on the forum and google but could'nt find it.
I'm willing to have a MIDI controller that has a "slider" which controls speed of the clips of my composition.
My composition it's basically a 1 layer with many columns, and autopilot that changes from column to column when needed.
As this is a project to be played with an philarmonical orchestra I need a way to control the speed of each clip on my layer.
My question is ... Do I need to map the Midi controller to every clip that I want to modify the speed of (there are around 128 of them) ?? Or is there anyway to tell Resolume Arena that a certain Midi Control change will be afecting the speed of whatever clip is playing ? (in my case, who tells Resolume to change from clip to next clip is Autopilot)
Does my question has sense ? Anyone has an answer ? Do I need to MIDI map every single clip or is there a way to control the speed of all clips at once ?
Thanks for any support ...
e*
Re: Controlling Speed with MIDI controller on ALL clips on a Layer
the composition has a speed slider which should do this, it's the one with the 'S'
