Dominant IAC Midi Trigger
Dalien
Post by Dalien »
Hey guys,
I am working on a setup to playback tracks out of Logic Pro X and sync them with clips out of Resolume Arena 6.
Therefore I am using the IAC Midi Driver inside of Mac OSX (Sierra)
The connection is stable and I can map my setup with different notes without a problem.
The problems occures once I playback the track from Logic.
At that moment Resolume won't let any other control happen. I can't stop the clip, or change it or change anything. By MIDI and by hand in Resolume.
I already tried to set the MIDI Trigger inside of Resolume to Piano. Bust still the same Problem.
I have to stop the MIDI Input in Resolume and restart the program to get it to work again.
Any suggestions?
Re: Dominant IAC Midi Trigger
Do you send note offs too?
What does your midi input monitor in preferences show as input?
Dalien
Post by Dalien »
No, there is no Off note.
I had a production yesterday where a technician showed me his setup. He just used a "GO" and it worked out fine.
I just checked it in Resolume 5. The Input is not really working properly but you still can control Resolume itself after
getting the MIDI Note run the Clip.
In Resolume 6 the Input works properly. Every Note is showing up fine as it should. But once the clip is triggered it seems like resolume is completly blocking every communication.
Preferences
Preferences
Midi Trigger
Midi Trigger
Bildschirmfoto 2018-01-27 um 18.41.40.png (97.85 KiB) Viewed 7551 times
Midi Pref
Midi Pref
drazkers
Post by drazkers »
Show us what your sending in the midi monitor.
I still think your sending midi out and creating a loop. :p
Dalien
Post by Dalien »
It seem like the problem already occures in Logic.
I am getting the same Monitor with Resolume switched off.
So there has to be a loop inside of Logic already.
Thanks for that. The Monitor was a Tool I did'nt knew before.
Dalien
Post by Dalien »
I finally found the solution inside of logic.
Because I still had the MIDI Track in Record Mode he was still receiving the MIDI Notes, that I just send from the same track. So your opinion of a feedback loop was correct. But not inside of Resolume.
