Moving Clip Position ( Transform )
VJ Psyberpixie
Post by VJ Psyberpixie »
I have a very Tedious project coming up, I have to resize and move clips and layers for a mapping project.
Is there a way to click and drag the file to position it, instead of doing the X and Y coordinates ?
Thanks in advance for any tips :geek:
He2neg
Re: Moving Clip Position ( Transform )
Post by He2neg »
You can drag n drop slices in the advanced Output, but inside you comp you will need to use the X/Y stuff
~Berlin~
VJ Psyberpixie wrote: Is there a way to click and drag the file to position it, instead of doing the X and Y coordinates ?
You can assign an keyboard key to the Selected clip's transform position X and set the shortcut mode to Mouse, horizontal. Set the range so you'll have finer control.
Repeat for Position Y, setting the mode to Vertical.
Exit shortcut mapping.
Now when you hold this keyboard key and move the mouse, it will move the selected clip.
VJ Psyberpixie
Thanks for the quick replies! I will try them both :)
🌟Keep It Lucid🌟
VJ Psyberpixie
help...I don't see :
I'm on Keyboard Mapping / Have selected the X / Y coordinates but my drop menu doesn't have or see :
"Composition Selectedclip Video Effects Transform Position"
i'm using Resolume 6
Thnx!
🌟Keep It Lucid🌟
Enter Keyboard Shortcut mapping.
click on the Position X on the selected clip panel,
push a keyboard key,
now you should see the "Composition Selectedclip Video Effects Transform Position X" shortcut created.
VJ Psyberpixie
Thank You Zoltan! got it now :P
🌟Keep It Lucid🌟
He2neg
Post by He2neg »
Didnt know that... This is a new R6 Feature isnt it?
Can be handy sometimes... Thanks for jumping in
~Berlin~
He2neg wrote: Didnt know that... This is a new R6 Feature isnt it?
It's available in Resolume 4 too ;)
