Autoplay, flashing one frame of next clip in transition.
ninjamosh
Post by ninjamosh »
Hi everybody,
Just got started with this amazing program, but having some small glitches. I have several .dxv (normal quality, with alpha) clips lined up after each other, autoplay is on. But when it jumps from one clip to another, there is a single frame flashing of the next clip. Tried with both hold on last frame, and end on last frame. Same result.
It seems to come and go, have not quite locked down why. One theory I have is that it happens whenever I edit the in or out point of the clips.
Any suggestions?
ninjamosh
Re: Autoplay, flashing one frame of next clip in transition.
Post by ninjamosh »
Some more info:
It seems to work when I restart, but suddenly its back. Suspecting its whenever I go into one of the clips and mess with them
Only 2 active layers.
Technical info:
Mac Osx 10.12.6
Resolume Avenue 6.0.9
Running an extra fullscreen tv output at 1050i.
What’s your computer?
ninjamosh
Post by ninjamosh »
2017 Macbook pro, 2,8 ghz, Radeon pro 560
Online
We're aware of this issue and are working on it (ticket #11131)
A workaround can be to have a small transition time set on the layer that hides the frame flash.
ninjamosh
Post by ninjamosh »
Ah, thanks for the info. Great to hear you are working on it.
Any tips for a newbie on how you set up that transition time?
Online
the_slain_man
Post by the_slain_man »
Also got hit by this. Can provide sample files if needed.
